Old 15-01-2008, 02:21
there's a lead that plugs onto the det sensor, and a then into the plug on the injector loom
Old 15-01-2008, 08:43
Jamie Hicks Jamie Hicks is offline
Jamie Hicks is an unknown quantity at this point
Rusty, Danny; thanks guys.
Ok, so I need another lead, that makes sense. I'll have a rummage through the car and see what I can find. Failing that I assume my friendly Nissan dealer would stock them - I want a new cambelt anyway. Er, and a water pipe banjo-bolt for the turbo, and probably some other stuff I've forgotten.
Oh yes, and I also need to find a turbo oil-feed hose, assuming I get a braided line made up, can anyone tell me the thread sizes I'd need?
Right, I think that's everything for now!
Cheers, Jamie
Old 15-01-2008, 15:35
if you can't get a lead you can just bridge the 2 wires with a resistor. The sensor itself doesn't really do a lot and you shouldn't rely on it fo knock protection, but if you dont fool the ECU into thinking it's there the timing will be retarded 5 degrees (iirc) over 2k rpm so you'll lose power
Old 15-01-2008, 16:05
Danny,
To be honest mate, if I can't find the lead anywhere it'll be a 5 minute job to lop off the round pin connector and wire up with some some spade connectors - thankfully the car is over a pit, so I can access the sensor easily from below. But I accept that it would run with just a resisitor too.
Cheers, Jamie
