Old 20-01-2008, 13:37
kylepiggy kylepiggy is offline
kylepiggy is an unknown quantity at this point
i have just done this mod yesterday and what a cee you next tuesday of a job it was i used t25 off 200sx with the 200sx downpipe from turbo only had to shave off a bit of the lug on the gbox but i have a mk1 s12 if that makes a difference. i also used the oil return metal pipe from 200sx and cut about 1" off it and with a bit of gentle persuasion lol the rubber pipe fitted like a glove. the hardest part was getting that bloody nut on the manifold the 1 at the bottom. took 2 hours of molesting and when it came off it took the stud with it. i changed the stud with a smaller 1 and it was alot easier to get back on just blowing now so need to order some more manifold gaskets. the oil line was piece of cake but the water lines were a bit hard to fit as the washers on the banjo bolts keep falling off just as i lined them up lol was very stressful. i also used the 3 bolt flange that comes from the turbo out to the intake manifold i just cut a bit off of the standard plenum pipe match up and used bit of silicone hose and 2 clamps to secure lovely job. i cant comment on performance as when i bought the car on friday the turbo was seized. i will be fitting boost controller this week coming changing spark plugs and either welding up that saftey valve or if i can be bothered blanking it off. hope this helps guys
Old 15-02-2008, 11:40
banana-man666 banana-man666 is offline
banana-man666 is an unknown quantity at this point
Has anybody fitted a t25 to an auto and fancy giving me any pointers?
Im guessing there is no lug to chop and is there anything else I should look out for?
Old 15-02-2008, 20:57
That question is better directed to Silviagod but I would also like to know as I have an Auto.
Old 16-02-2008, 18:13
if you use the s12 elbow as I've said to a few people, there's no modification needed to the gearbox as everything sits in it's original position
Old 16-02-2008, 19:38
You also need the s13 compressor side outlet 3 bolt flange/pipe
You can only use the s13 oil feed pipe on a mk2 s12 mid 1986 onwards as the mk1's have a feed from around the other side near the oil filter
Old 17-02-2008, 23:32
Ah right mine is a mk1.
Ill have to have a further llok at everything under bonnet then
Cheers guys
Old 18-02-2008, 04:00
just to be odd, my c-reg auto mk1 had the oil feed on the turbo side of the block. Havn't a clue why but it was 100% the original engine
