Old 11-02-2008, 18:10
Paul Smith Paul Smith is offline
Paul Smith is an unknown quantity at this point
I tried two different leads and 2 different plugs straight from the ignition coil and neither sparked?
Could this be leads still or plugs ?
Old 11-02-2008, 18:25
Dr Silvia's Avatar
most common cause of my silvia not starting was plugs covered in coke
take the dizzy cap off and examine the contacts; if they are dirty buff them clean with fine emerycloth/fine abrasive paper, if they're mangled [unlikely]then replace. test this by checking for conductivity from dizzy kingpin lead across to htlead pins while turning engine by hand.
if you have a multimeter put it on 20v range and over primary windings of coil see if you get 12v; otherwise maybe a spare bulb likea fog light?
Old 16-02-2008, 19:32
Most common fault is a bad earth on the coil
This maybe a rare one but check that there is a 12v feed to the distributer.
I dont know the wiring diagram in my head but i know i lost this feed on my et once i put in a new one via a switched relay.
Old 18-02-2008, 04:05
definitely check the coil is earthed OK, it's earthed to the body where it bolts on, and it can rust there a lot.
is that Paul "drifty skyline" Smith?
Old 24-02-2008, 20:36
sorry for the delay in replying, thanks for the advise.
I was looking today, the coil i have now cleaned up but still no spark i have checked that fuel is coming through. It is pumping in to the chambers i think there was a lot of pressure behind the fuel when i undid the hose.
I was wonder how the is setup do these engines have a crank position sensor ???? if so any pics, if not what do they use.
any other ideas would also be a great help.
anyone one got a spare ignition coil plugs leads and distributor laying around that all work for sale???????????
Old 24-02-2008, 20:40
zxocmars zxocmars is offline
There is a Crank angle sensor, but not sure that would be your problem
I'm no expert by any means, but if the CAS was out woudl it not still spark, but out of sequence?
Might have a spare one somewhere
Old 24-02-2008, 20:42
i figured that if it was broke it wouldn't tell anything to spark???
Old 26-02-2008, 12:15
old-and-rusty's Avatar
Hiya,
The crank angle sensor is built into the dizzy itself.
If you know how to run the Self Diagnosis process on the s12, you will get an error code No.11, if the CAS is faulty.
Hope this helps .
Regards,
Ian.
Old 27-02-2008, 15:20
its in the dizzy??? how could i check this??? or should i change the distributor for one we know works. Anyone got one for sale?
