Old 23-02-2008, 21:32
The best part of doing this conversion is so that the corner weights of the car can be adjusted.
Old 19-03-2008, 20:18
Hi guys, Latest up-date is a few pictures of the coilover adjustable top mounts I bought on Ebay, they require some minor tweeks to fit an S12 as they were intended for an S13.
The special top nut( 24mm AF hexagon bar showing 10mm above a 20mm long 18mm dia shaft with a M12 x 1.25 thread tapped with a 3mm 12.5 dia counterbore at the bottom) and lower bearing support ring(25mm dia outside x 20mm inside x 11mm high).
The coilovers assembled.
And finally the coilovers on the car.
Hans and Paul.
Old 20-03-2008, 22:52
paulsilv's Avatar
paulsilv paulsilv is offline
Hans you are a God, will you be offering these coilover kits to members?
Looks very very tempting
Old 21-03-2008, 00:16
feck me, do it yourself, its easy enough, i ain't got any welding gear, but i did the fabrication myself, then got it all welded up.you lazy bugger lol.
Old 21-03-2008, 00:47
The KYB shocks have a different stem, so it was really easy to fit the top mount to them when I did it.
Old 21-03-2008, 08:33
lol well said
Old 21-03-2008, 10:50
Yes I will offer a built up kit for about £400 to customer spec once I have tested mine out!
I have a set of S12 legs spare now so I will prepare them soon.
Just fitted them to the car this morning and adjusted the camber to the max.
The car looks the tits now I think!!!!
I also did a few other jobs like welded the steering boss on and bolted the new OMP steering wheel on. I also took a bit of the fan blades as they would touch the under side of the intercooler pipes under driving conditions.
I cannot wait to drive it.
Hans.
Old 21-03-2008, 11:05
you won't be short on cold air on the i/c
