Old 15-02-2006, 13:17
gripo's Avatar
gripo gripo is offline
Default gripos progress
alright guys. Well i have just got back from sunny northampton where i have dropped my T3 off at turbotechnics for a 360 bearing. Was thinking about having the blades cut back to 75% but although it would give more grunt up the top i would gain in lag so i have just kept it to the 360 bearing. Hopefully the seals are ok otherwise i will be paying 250 plus vat unlike the 125 plus vat for the bearing which i dont think is too bad at all.
Right i am having lunch now and then i am putting the power steering pump, alternator, belts, etc on and then start cleaning her.
tomorrow i am picking up the hyundai radiator and hopefully fitting that. Still need a bluebird thermostat housing anybody???????????
Old 15-02-2006, 14:08
try the zxoc paul, or get the chassis number from a bb, then give nissan a bell, surley it won't be to much.
Old 15-02-2006, 15:27
datdrift's Avatar
datdrift datdrift is offline
i have got a bb turbo one, but i may need it when i fit a cooler? i have got a ca18s in my garage that has one that looks the same, but im unsure if the bolt holes would line up,i would check but its raining i'll have a look later or tomorow if you still need it
Old 15-02-2006, 15:31
The CA18S I think is different
Old 15-02-2006, 15:50
datdrift's Avatar
no it is the same just took it off, and it looks exactly the same as the bluey turbo one, just to be sure i bolted it to a spare ca18et head-
i would like £4 or summit for it tho pm me if you want
Old 15-02-2006, 15:54
Thats lucky..
Some of the bluebird ones are only 2 bolts
