Old 04-03-2008, 19:18
check the vacuum pipe from the inlet fanimold. If still no joy email Silviagod
Old 04-03-2008, 19:36
Oscar's Avatar
Oscar Oscar is offline
cheers will do, the fluid level was nothing 2 write home about, very small top up, il do another vacum check,
Old 05-03-2008, 15:45
Oscar's Avatar
would say a low oil level/knacked diff be 2 blame?
Old 05-03-2008, 19:12
the diff will have nothing to do with the Auto box
Old 18-03-2008, 23:06
Oscar's Avatar
right in between the s15, bin tinkering with the s12, and ive noticed when this problem occurs, the fuel pump runs like the clappers and never switches off! Is there a fuel regulator on these cars? And ive checked the wires 2 the pump, would overfueling cause these probs?
Old 19-03-2008, 08:19
Fuel reg is attached to the fuel rail. The auto box would work regardless
Old 19-03-2008, 11:51
Oscar's Avatar
right the problem is now, voltage goes right up, idiling in neutral is fine, in drive etc it cuts out, idles too low, and if u try and drive it, its very sluggish, and wont change up, and fuel consumption is bad, then if i run it for 10mins, switch it off, then its fine. Then few hours later it wil do it again!
