#31
Depends how hard you treat it,
A standard manual apparently can't withstand sustained abuse from a standard ET http://www.nissansilvia.co.uk/vbb/sh...?t=3037&page=2 |
#32
good point...
#33
I think I read somewhere, (here or zxoc) that a standard auto should be good for upto 350hp under "normal" conditions
Not sure if that's true though |
#34
i think the silvia god says around 200bhp before it starts to slip, my auto box must be shot as it slips @ 12psi with just an airfilter mod
who ever started that rubbish off either has never checked/serviced there gearbox oil and cant change gear properly. Also i have never read anywhere about an s12 autobox handling 350hp. I would trust silviagods experience here. sorry if this sounds rude,i dont mean it too be
![]() Quote:
#36
i shall also then! Cheers
#37
TBH my autobox couldn`t handle 200bhp
. The gearbox couldn`t cope with the kickdown. I had the box fully reconditioned too and it still let me down.I would definately go the manual route, if you are looking at higher power outputs. Regards, Ian.
well im hoping 2 do the sr20, sometime in the future, but 2 save hassle felt like doing the det conversion 4 now, with auto as i can get nearly everything 4 free or very cheap. And do the manual when i do the sr,
#39
I guess if the parts aren`t going to cost much it`s not too bad if the autobox goes boom
...LOL... As long as you are careful with the kickdown, you should be okay. My box used to expire when I got to eager with the right foot...LOL....Regards. Ian.
I never hear anyone about the power transistor (DIS-4 modulle)
I found out that its not on the engine loom but on the chassis loom. Cant figure out how to hook that up.
87 silvia (ca18det) 94 Alfa Romeo 155 2.0 8v ts (daily driver)(planning Lancia Delta swap) 84 silvia (ca18et oldtimer) Turbolag is nothing but foreplay |
