Old 19-03-2008, 20:30
Your questions if they are questions are all jumbled.
Old 20-03-2008, 12:54
Oscar's Avatar
Oscar Oscar is offline
sorry lol, here are the symptoms. Engine tries 2 cut out in drive. Fuel pump very noisy. Lacks power. Struggles 2 change up. Exhaust goes quieter and no poping and banging. But it only does this first drive of the day, very rarely continues after the first drive. Think it could be the fuel system?
Old 20-03-2008, 19:19
it could be anything from the ignition timing to fuel pressure reg for example. Your going to have to work through the list from before on your last thread.
forget the auto gearbox from the equation at the moment.
also remember previous issues ie your injector plug and afm
Old 20-03-2008, 20:48
zxocmars zxocmars is offline
If it only runs rough at the first drive, I wouldn't rule out damp in the dizzy.
Old 20-03-2008, 20:59
oscar why dont you bring the car up take me a run out in it & lets see if we can sort it out , i have got loads of spares that we can try. let me know when
Old 21-03-2008, 15:57
Oscar's Avatar
would wednesday be ok? I stripped all the injector plugs off 2day, cleaned em all up, not much diference, but if i wiggle the main injector harness it hunts around, so might be a break in the cable somewhere..
Old 21-03-2008, 16:03
thats fine, infact i had a cracked wire on an injector,have you tried running the engine, then disconnecting the injector plugs one by one, try it whilst its acting up, you should be able to see which one it is.obviously disconnetind 3 out of 4 of them will make it worse.
