Old 26-03-2008, 14:43
WM-S12's Avatar
WM-S12 WM-S12 is offline
can't say I know what the problem is but I wouldn't necessary say it's your turbo that's making the little smoke. I thought that and taking it to a performance garage I found out the smoke was due to oil in the 3rd cylinder. ( probably my piston rings have too much wear. ) also the guy noted I had something to do with compression in the 3rd and 4th cylinder....if I remember correctly one had higher than normal and one was lower than normal.
Gonna scan my email as it's in there somewere, let you know what I got told when I find it.
Old 26-03-2008, 14:51
WM-S12's Avatar
Inlet pipe to turbo removed - oil in turbo inlet.
Engine started, breather pipe removed from rocker cover - crankcase compression at the breather just with engine idling.
Spark plugs removed - number three plug burnt on deposits - burning oil in number three cylinder. Others burning clean.
Compression check carried out.
Compression (psi). 1 - 170, 2 - 170, 3 - 130, 4 - 100
Other turbo supplied has more play in the bearings than the one on the car.
Suggest problems are being caused by worn engine which requires further investigation / rectification before turbo is condemned.
thats the exact qouting from the guy at the garage I took my car to fix the apparant manifold problem.....turned out to be just the gasket so I bought a second hand tubby and manifold for £130....only needed the elbow and gaskets.....
As for smoke, my car barely smokes unless it sits for over 10 minutes idling below 700rpm some times nears 500rpm ( lol....chug chug ) but it's not belching out. Nor does it puff any when your belting it as the oil will simply be burnt all quicker.....really needs a new engine or atleast a rebuild.
Old 26-03-2008, 18:57
are you getting excess crankcase pressure or a pressurised cooling system?
Old 27-03-2008, 00:54
WM-S12's Avatar
I'd check your sparks to be sure that you ain't got the same problem I got with the 3rd cylinder. Just an idea.
well from what the guy put in the email to me he just stated crankcase pressure at idle.....no idea if theres ment to be any or what. ( plus I've no idea who your directing the question to )
Old 27-03-2008, 07:52
no idea? how about the guy who started the thread off asking the question
i would say unless it improves from driving it a bit more since its been worked on your best off taking the head off Northerner, although im sure you know that already.
Old 27-03-2008, 13:33
thanks for that. I'm just sounding out ideas before I go with the renewing the HG. I kinda hoped not to do that as its only done 45k but sounds like its a must
Old 27-03-2008, 15:41
Do a homebrew leak down test before ripping apart the engine.
