thanks for that. I'm just sounding out ideas before I go with the renewing the HG. I kinda hoped not to do that as its only done 45k but sounds like its a must
Do a homebrew leak down test before ripping apart the engine.
H'mm you've got me on that one?
Get an old spark plug, hack it and drill it out so you can get something resembling a hose on it, or use an old compression tester and hack it.
You then only need to apply actually low pressure to identify a leak. I used an old pressurized gardening water can thing for this. Then use a foot long petrol pipe, shove it in the inlet manifold, oil filler, or exhaust/turbo to see where you can hear a hiss. If it does turn out to be rings, or a damaged piston (eg detonation) then I wouldn't bother attempting a repair. Be easier to find another engine
