Old 03-04-2008, 15:12
The inside ball joint of the track rods is pretty large, when the rack is on full lock the ball joint locks up against the rack.
By using washers, you move the ball joint further away and therefore it locks later.
The car will ideally need retracking afterwards.
Old 03-04-2008, 16:06
Turbonormal Turbonormal is offline
Turbonormal is an unknown quantity at this point
ah I see, so it isnt to do with greater track then, simply to allow the rack to travel further in either direction.
Old 04-04-2008, 23:42
There for people who cant do 3 point turns.
Old 07-04-2008, 21:58
hahahaha
Old 08-04-2008, 11:25
Hi guys,
Did any of you take dimensions of the diameter internally and externally? it looks about 5mm thick to me which should add quite a few degrees to the angle of the wheels.
This would be jolly useful as this is our next mod.
Hans.
Old 08-04-2008, 21:15
I have a pair of these somewhere, I can measure them for you if I can find them
