Don't really no the fella i bought it off said they were s13 shafts cause he was goin 2 put a s13 lsd in it to put it on the road
I doubt highly you will have S13 shafts
Yea i really don't know i'm just goin on what i was told when i bought the car and wouldn't know enough about them to say any different
s14 diff fits handy enough into s12 casing. just swap crown wheel and put back in. shafts are another story. theres one s12 shaft shorter than the other. can't remember which side it is though. anyway you need 2 short s12 shafts s13/14 diff and inner drives. the left hand s12 shaft needs to be shortened to avoid shuddering. little time comsuming but worth it if you want a bit of sideways action
Someone tried fitting an S14a diff and found the shafts to be thicker. So therefore they couldn't grind the S12 shaft shorter as it didn't have the required girth.
i've read somewhere that an s15 helical will fit if you have the six bolt output shafts.Has nobody tried fitting 1?I've had enough of spinning 1 wheel!
left hand shafts are the shorter ones duncan
