Thanks for the quick responses, looks like i better get a rebuild kit! it cant be that hard or can it?
diy rebuild kits are not worth the aggro. they rarely work
and you cant balance the shaft. A recon turbo is around £250
see adzs for details lol.
If you know where i can get a recon turbo for £250 please let me know as im getting quotes of 4/500
i only payed £570 for a brand new not recon genuin garret t34.
Try Jack@Turbo Repairs Blackpool 01253 407464 as long as yours is serviceable he can recon it for about £250 all in inc collection/delivery. He can make up any to your spec and can make a T2 hybrid ie with bigger compressor which I had and makes loads of difference. Good thing about the hybrid is that it fit a standard engine/pipes
http://www.turborepairs.com/parts.html
Yeah. Adz did a spot on job when her did his. Marked everything up and torqued the shaft nut correctly, Even then it only did a few hundred miles. Ebay kits just are not precise enough
found a local place for £300 exchange so will go for that one, getting the turbo out went ok up until one of the metal coolant pipes snapped! will probably get another made locally as cant see nissan having one, thanks for help all
F$%k mine does this too, I just thought it was just the zorst coz its blowing right next to it, bet my seals have gone too.
Got more soul than a sock with a hole |
