Old 26-05-2008, 18:12
Beany-s12's Avatar
There's a big bracket in the way on each arm. You have to be a man and squeeze the shafts in tight to clear it. Or you can be a woofter and remove the bracket, which seems to bolt to the bottom of the shock if i remember correctly.
i must be a man then Grrrrr
Old 26-05-2008, 19:28
RichardK's Avatar
RichardK RichardK is offline
Forum Administrator
No, having a big dick makes you a man. I'm a hell of a man
As for the diff, tomorrow will tell. I'll make a how to afterwards. I have a bad back tho so won't be overly easy anyway grrr!
Old 26-05-2008, 19:29
Originally Posted by RichardK View Post
No, being a big dick makes you a man. I'm a hell of a man
Old 27-05-2008, 07:56
[quote=RichardK;26120]No, having a big dick makes you a man. I'm a hell of a man QUOTE]
Depends where the dick is . . . (ie sitting on it doesn't count)
