Old 30-05-2008, 12:27
old-and-rusty's Avatar
I haven`t had chance to weigh up the fronts yet Martin. But I`m planning on fitting the complete s13 rear subframe, diff, suspension, shafts etc complete. I`ve been measuring up the floor pan because I`m undecided yet wether to transfer this (from the back of the transmission tunnel to the boot slam panel) or just use the strut towers and subframe pick-up points. I know that the complete s13 rear axle is a little wider, but that doesn`t matter as I will be doing some extensive bodywork (including rear arch extensions and possibly even rear tubs).
Hope that all makes sense . Plus I`m looking at coilovers all round too.
Regards,
Ian.
Old 30-05-2008, 12:42
If you use S13 aftermarket coilovers you could use S13 front hubs and ABS gubbins.
The wiring shouldn't be that hard if you can get the diags from the S13 manual (think I've got a PDF one somewhere), certainly should be something an auto-electrician would cope with. Then you've just got to work out the bits under the bonnet.
Old 30-05-2008, 14:03
You'd need the S13 master cylinder too. It's got just a F & R output as opposed to the F/R, F/L and R on the S12
Old 30-05-2008, 14:22
Thanks Dan, but I`ve got a full PDF version of the s13 Service Manual. Plus I labelled all the loom as I disconnected it (as well as taking loads of notes) .
I`ve saved every single part from the s13 (including all fasteners and bolts...LOL...), so I know I have all the parts for the conversion already. I just need to make up a couple of new brake lines, which won`t be a problem, as I`ve got pipe flaring tools etc. Plus by using the complete s13 axle assembly, I can use the diff oil cooler that came off the car.
Sorry to hijack the thread Rich .
Regards,
Ian.
Old 30-05-2008, 15:10
I was kinda offering the Manual for Richards benefit as he'll need to make a separate loom up
Will an S13 MC bolt to an S12 Servo and work? Is there a difference because of the ABS? Have you compared the two Ian?
Old 30-05-2008, 15:12
I'm pretty certain it will bolt on. If a big Z32 one bolts to my Datsun then it's likely an S13 will bolt to S12
Old 30-05-2008, 15:24
Sound's like its do-able. A machine shop could probably attach S13 rear wheel speed sensors to the S12 output shafts... somehow
Old 30-05-2008, 16:06
Sorry Dan, didn`t realise you were offering Rich the info....LOL...
I haven`t compared the servos side by side, but I do know that s12`s used the G32 or M32 servos whereas the s13 used the M195T servos. As Martin says the MC`s are totally different - the s12 has a bigger cylinder bore and different outlets.
I will compare the two servos next time I`m in the garage and post up the results .
Regards.
Ian.
