  #18
Old 31-05-2008, 11:12
old-and-rusty's Avatar
Dan,
The rear sensor can be found once the prop is removed. It`s just behind the flange that connects the prop to the diff (so just one bolt to remove the flange) .
I wonder if you could rig up the set up that a lot of kit cars use for the speedo sensor on the front hubs, do you think that would work Martin?
I know that TVR`s use this type of idea.
Regards,
Ian.
