Old 08-06-2008, 22:18
It hasn't jumped a tooth.
Chances are, as RK said it's flooded.
Get in to the right hand boot compartment and pull out the tray. Under there is 2 plugs. Disconnect the 4 wired flat plug to disconnect the fuel pump. Then try to start it and hopefully it will clean itself out a bit and then reconnect the pump.
