Old 09-06-2008, 13:29
or take out the fuel pump fuse and try drying the plugs
Old 09-06-2008, 13:51
Taking out the fuel pump fuse will stop it sparking though. You need to try to burn off the old fuel so best just to disconnect the pump.
My mate flooded his so bad the only way to get it started was to tow it and get the engine spinning at 3k
Old 10-06-2008, 21:02
RichardK's Avatar
RichardK RichardK is offline
Forum Administrator
Take out the plugs, dry them with kitchen paper, put them back in. Turn the engine over with the fuel pump disconnected.
I can cut my fuel pump off with one of the immobilisers but otherwise do as Martin said and unplug it.
S12's are brilliant at flooding themselves!!
Old 10-06-2008, 21:06
when mine does that, i just take the water temp sensor off straight away and it fires up with a couple of turns.
Old 16-06-2008, 18:07
Dazmans12's Avatar
Banned
Default wont start
Hi
Some good tips here for you. Here's a cuople more for you to check over, If fuel pump is on its way out then may not be enough pressure to fine spray the fuel into the cyls, so could just be dribbling in via injectors & flooding engine. Try getting a pressure check for the fuel, eaisy to do, happened to one of my s12s, however I was able to run, so long as it was on a flat road, any need for power & she would splutter & cut out. My S13's Fuel regualor, when it packed up, did the same & just wouldn't start, but I ve no heard of
S12 fuel regualors going.
You can dig out the ECU,(is located in the side pannel of the passenger footwell) & run a self diagnostic, which might point you in the right direction. newer ECU's have the fault codes written on the top of the box.
if the AFL(Air flow metre) is knackered, or has become disconnnected.
As has been said, if any of the air intake pipes, turbo to plenum chamber is disconected then def wont start.
Just a few for you to look into.
Good luck
daz
Old 16-06-2008, 19:00
zxocmars zxocmars is offline
Thanks for the info Daz and everyone else
I went to try some of these ideas at the weekend, but my mate had decided to have a go for me and has stripped all the pulleys and belts off, so I'm just gonna leave him to it as I don't where he got up to.
haven't seen him this week to have a go at him - I hate it when people touch my stuff without asking.
oops, double posted.
Old 16-06-2008, 22:24
Does he know what he's doing? You can check the cam timing without doing things like that. Tell him to use a timing light next time
