If you find a set of S13 coilovers for the front then you can always get some adjustable telescopic made for the rears. Somtimes you see coilovers going for cheep with a broken rear in the set.
http://www.silverstonetuning.com/pdf/KSX.pdf And have a look at this thread for an idea of how much it would cost to get some springs wound up for you.. http://www.nissansilvia.co.uk/vbb/sh...rkshire+spring Also don't forget that if you lower the Standard 12's they get a hideous amount of negative camber on the rear so you might want to look into slotting out your rear subframe... http://www.club-s12.org/forums/index...20camber&st=20
Ah ok, will have a word with the mechanic dude and see what he can do with welding the suspension mounts.
p.s. lots of negative camber is good on drift cars so yay!!
You want negative on the front certainly
