Old 12-06-2008, 17:20
Paul Smith Paul Smith is offline
Paul Smith is an unknown quantity at this point
Ok i'm new to hydraulic clutches, i have bled the air out the slave cylinder but it still doesn't work. The slave cylinder dust cover was full of fluid so i took it from the car and cleaned it and sealed the attching pipes but seemed to have built some vacuum in the dist cover its drawn all the air out of it? Does it sound like its bust? where can i get a new one? Any other suggestions are welcome.
when you say force it in gear you mean when its running with fluid in?
Old 12-06-2008, 20:09
tractor-boy tractor-boy is offline
tractor-boy is an unknown quantity at this point
Ya can get a new one for nearly nothing from any decent motor factors.
Does the pedal feel either really heavy or really light when ya press it?
Old 12-06-2008, 21:51
old-and-rusty's Avatar
If the clutch disk is stuck try rocking the car backwards and forwards (as northerner says). You need to do this with the engine switched off and the car in third gear. I had to do this with my Dad`s old A40 last year after it had been stood for 12 months .
If the slave cylinder seals are shot, the pedal usually goes light or drops to the floor. If the piston in the cylinder is stuck, then the pedal is normally rock hard and can`t be pushed down.
Have you had the engine or gearbox out at all. Because the clutch may be mis-aligned.
Hope some of this may help .
Regards,
Ian.
Old 13-06-2008, 19:21
I have ordered a new slave cylinder so should pick that up tomorrow i will try and rock the car in 3rd as well see if that helps
thanks again
Old 14-06-2008, 10:28
Hope you get it sorted .
Regards,
Ian.
Old 15-06-2008, 00:09
WM-S12's Avatar
WM-S12 WM-S12 is offline
I had that exact problem a good few months back, same symtoms, I just replaced it an it works perfectly fine.
Old 15-06-2008, 14:39
will i have to bleed the clutch with the new slave fitted? hope this works
