Old 21-06-2008, 17:34
t51rjohn t51rjohn is offline
t51rjohn is on a distinguished road
To be honest you'll probably find it won't make much difference for most panels esepcially say the wings. They're so light anyway.
Bonnet and hatch should be essential though, the rear hatch is probably at least twice the weight of the bonnet.
Lightweight versions(Race) can be made which would be less layers or with other composite materials like Carbon or Carbon Kevlar, Also with race fitment there is no catches on the under side of the bonnet it would be a bonnet skin which is rigid enough to keep its form but keeps weight to a minimum.
Thanks John
Old 21-06-2008, 17:36
Also with the fibreglass doors please be aware of the safety implications, ie no good in a side impact ensure you have a cage with door bars before fitting!!
Also for a road car as mentioned before these can be broken into easier than metal if you right tools!
Thanks John
Old 21-06-2008, 18:47
would the bonnet be ok at high speeds?, as the guy with the red race s12 had to put some strenthening bars in because it was flexing at speed and i will possibley doing top speed runs when its finished.
Old 21-06-2008, 20:12
martin.herwitson's Avatar
Default Count me in!
I'd love a pair of front wings!!!!! no more isopon! and possibly bonnet doors and boot for that matter!..
Old 21-06-2008, 23:01
Aramid cloth could be used to stiffen it up if required, i doubt it would though.
The main thing that would cause a problem is if the bonnet isn't securely fastened, the bonnet will flex, but that is just the characteristics of the materials, hence aramid to strenghen it. However Aramid is quite expensive so costs would rise.
Thanks John
Old 21-06-2008, 23:07
just had a look at aramid prices and it should be about £75 more for aramid reinforcement, however is still feel this is unecessary as it will be plenty strong enough, i am using good quality fibreglass so it will be very stiff.
Thanks John
Old 01-07-2008, 00:39
carrottop carrottop is offline
carrottop is an unknown quantity at this point
Hi mate am currently after a pair of front wings for my s12 and fiberglass sounds like a good solution when your ready let me know and i will definetly have a pair off you cheers Phil
Old 01-07-2008, 19:22
you only need to roll up some card or similer and make a corner to corner diagonal cross structure underneath and then another one on the front lip of the bonnet and then fibreglass over with the second or third layer. That will strenghten it enough for about 20p and it looks prefectly fine
then measure the bonnet thickness where the hinges bolt on and then put in some wood between the layers in the corners to the right thickness. You can then screw the origianl hinges to it
It wont be strong enough with out reinforcement unless your going to make it really thick and heavy
