Old 30-07-2008, 09:24
it does the same noise from manifold to head as well.
Old 31-07-2008, 23:38
rob turbo's Avatar
hhmm, thanks for your inputs guys, however ive just had the manifold gasket done + checked the seals in around the turbo.. do's not sound like it's from the engine realey, will do it stood still & rev it.! a weird one this, driving me crackers.!
any more suggestions..?>
cheers
Old 01-08-2008, 08:30
Was it doing it before you had that work done?
Old 05-08-2008, 20:19
rob turbo's Avatar
all ok, we had to take the inlet manifold off as there was a water leak from one of the pipes that, like to cause you untold greif to get to. we nailed it back together using instant gasket... hmm that worked.!
so after i spat that out, along with all the water, i took it to my tuners, he put the head gasket back & nailed it all together again, then this noise started.. a small murmurr, now a good wacker of one..
just a screach as it's boosting.. no loss of power, no visable adverse effects..
just this noise, painfull it is.
