Go Back   S12OC UK Forum > Event/Meets > Motorsport
Old 07-08-2008, 23:15
smoker's Avatar
smoker smoker is offline
Originally Posted by Pukka View Post
Polybush the front anti roll bar bushes,- or replace with new originals
Get some stiffer springs all round with reduced height of at least 35mm.
Run a 50 sidewall profile tyre at the most. toyo 205-50-15 tyres will work well,
Replace your front dampers If you have not already
Fit a front strutt brace
Cheers pukka
I have nearly new front anti roll bar bushes from datsun but was thinking of polybushing them and the drag links.
I'm liking the idea of lower and stiffer springs , are they available of the shelf ? , was pitching diving and rolling all over like a sea trawler in a storm on the track . Will filling the shock tubes with atf fluid be ok or should i upgrade them ?
Can i keep the origonal wheels if i run the toyo 205-50-15's?
