Old 31-08-2008, 18:56
doski's Avatar
doski doski is offline
There is a guide for the ca18det on here have a search and read, see if you think its easy enough, i have done it but i went the tidy way and did the whole relay box for the det, and sorted the rev counter so it works. i would stick with the 12 and go for that option as you have the det laying around and get it running and road worthy and just sort the little things over time when you driving it about
Old 01-09-2008, 08:37
Sharas's Avatar
Sharas Sharas is offline
I would go with the det in s12 .
I envy you doski. I made my swap not so tidy (basicly just to make it work), took me ages, and then decide to do all the suspensio and brakes and all the little things also, so its been 2 years and my car is still in the garage
Old 01-09-2008, 22:50
doski's Avatar
I had mine running fine but gearbox went so decided to go for det gearbox aswell rebuilt and has been off the road for nearly 2 years as i have rebuilt the whole car and gone to stage 3 300 bhp car is nearly ready for body shop now
Old 06-09-2008, 18:53
ste00 ste00 is offline
looks like i am putting the ca in it then...
will the s13 brakes fit? as i had just done the discs and pads on the 13 before i started braking it...
Old 08-09-2008, 11:17
They bolt on if you use S13 lower arms and hubs. Might also want to swap Steering rack so that you can use S13 Track Rod ends as the S12 ones are a pig to get hold of and don't offer as good adjustment with S13 hubs.
Old 08-09-2008, 17:06
You don't have to use the S13 arms and with the steering you need both the track rods and ends off an S13 and then they need shortening.
Old 14-09-2008, 20:19
well i have started this... got cuts all over my hands and arms my back is killing and 4 showers after i last touched it i am still covered in oil so it must be going well
bit confused on what wires go were tho... especially about the 3 green relays anyone got a step by step of the wireing?
and some one has hid the ecu on the s12...
just started getting some more money in as well so getting tempted to take the engine to stage 2 but a bit dubious of wether the gearbox would end up in the boot or not...
