does anyone know if the s13 steering rack bushes will fit the s12, as i wanted to replace them with poly ones.
Martin and I looked at this a while back, think we worked out one is the same.
Could look at using an s13 rack, that way I'm pretty sure the s13 bushes will fit (as long as you get the right clamps to the subframe) should get better lock too. |
i tried looking into it but struggled to get a definate answer so just ended getting some new orginal ones from nissan, which are still easily available to my knowledge
