thanks
more pics after a clean n polish with the flash- ![]() ![]() ![]() without ![]() ![]() ![]() ![]()
looks good rob, just need the front a shade lower, you will be able to do that if you buy my front coilover set up
would love to, as always tho, money is a major factor - how much is it?
on a random tangent, how much of a spacer could i use with the standard studs? (ie 5mm, 10mm etc)
if you use H&R hubcentic wheel spacers you can have 20 or 25mm
