Old 07-12-2008, 21:53
tractor-boy tractor-boy is offline
tractor-boy is an unknown quantity at this point
The covers just pop off on the rears then a couple of screws. Never had to do the fronts.
Old 08-12-2008, 12:29
old-and-rusty's Avatar
The fronts are pretty easy too . A couple of screws for the armrest, one screw in the top corner (just below the door mirror). But be careful when sliding off the trim piece round the handle for opening the door. The trim has to be pushed (can`t remember wether it`s backwards or forwards), but the tabs on the back are quite brittle and snap easily. Then just a couple of screws in the rear light (bottom corner of the panel) - if fitted and disconnect the leccy window switch. The trim piece above the window switches unclips then 2 or 3 screws holding the switches in place. Then over to your trim tool to take off the door card. Unclip it bottom, left and right, then push the door card up so it releases from the bottom window seal.
I think that`s everything....lol...
Regards,
Ian.
