Old 09-12-2008, 00:06
paulsilv's Avatar
paulsilv paulsilv is offline
i got the second one for my E "88". Had to modify it slightly. its a while since I did it.
Think I had to make a template from old one to drill another hole in the right place, then after that it wouldn't select 2nd, 4th or Reverse as it was hitting the back. I took a dremel to mine and slowly worked away at it trial fitting as I went until all the gears engaged.
It was quite a satisfying little job to do.
