nope mate i din't bother, to start with i was pissed off, but to be honest, theguy had only just got the dyno dynamics RR, i think he was used to setting v8's up, he tunes tvr's, he had the rampage all wrong and it only reved to 4900/5000 then took a reeding
it only seemed to be on for 20 seconds, it never even opened the external wastegate, i think it hit 10psi, it needed to hit 6800rpm and 17psi, but never mind, it still hit 250bhp at 10psi , it had no fans or owt, but its going back on next week, he's fetching a fan on monday my timing was probley retarderd from heat soak as well.
what ECU do you run Shaun?
its on an omex, that turbo don't start on boost till 3800rpm, it only hits 5psi by 4400rpm then it starts rushin in, but the run was over far to early, it din't get time to get the boost or revs going
