Did the 2 litre dohc fj20e come with a turbo because the one i'm after is the turbo model
Thanks Gary |
not over here, in japan they relesed the fj20et 2 litre turbo.
but if you are after the turbo its the 1.8, farly easy to get 200bhp and light and compact you would be lucky to come accross a 2.0 anyway, as they are fairly rare
Ok thanks mate
Check the following....
Sills for rust bottom of the wings under the mudflaps for rust Check that the rear brakes are not siezed that the indicator stalk is working correctly/Both flip up lights are working there are no manifold to head studs missing or that the gaskets are blowing Listen for gearbox 'whining' Check the fuel tank for leaks The rear boot lid struts hold the boot lid up Play in the windscreen wiper mechanism check the engine for excessive rocker/crankcase pressure. remove oil cap while engine is at idle. it should not drop more than 150/200rpm While test driving check the clutch bite, gearbox sycromesh is smooth and the turbo is operating properly with no smoke on gearchange/under boost. Also check that there is decent oil pressure Standard the turbo is set at around 6psi and oil pressure should be at around 40psi at 2000rpm
![]() Quote:
Thanks a lot mate I'll keep all that in mind
Worn piston rings
