Old 17-09-2009, 21:08
nedge2k nedge2k is offline
Administrator
i did
http://www.nissansilvia.co.uk/vbb/sh...&postcount=280
yeah from afar she looks great....unfortunately the arches aren't, the paint is bubbling in certain areas, back of the sills are fudged and oh yeah, check out my speed hole:
i also have no idea what the colour is....although it does look VERY similar to some old rover 200 series colours so i might get lucky when trying to match...fingers crossed!
Old 17-09-2009, 22:20
holey rear arch batman lol .
Old 18-09-2009, 19:19
Bloody hell. Is that a reflection of the work put into fitting the bodykit ?
Still, nice car. Seeing that really makes me want to put the Mk1 grille & sidelights on mine!
Bear in mind spacing the rears will, in-effect, exageratte the camber, possibily leading to heavy inner tyre wear.
Old 19-09-2009, 22:35
Administrator
the kit isn't too bad, there's a couple of paint issues but it seems well fitted enough. the spoiler doesn't feel overly secure.
as for the lights, if you've got a mk2 grille and sidelights, i'll do you a straight swap if you want?
Old 20-09-2009, 06:49
that looks like a modified mk2 grille with mk1 side lights, i have the mk1 grille, and its like honeycomb effect.
Old 20-09-2009, 13:21
Administrator
it is, yeah. always preferred that style to the honeycomb, looks more 80's
Old 20-09-2009, 17:08
You're on! PM'd.
I wondered if they damaged the underseal or something when it was fitted ?
Old 20-09-2009, 19:32
Administrator
tbh the underseal *looked* ok but as you can see from the pic, there's some black spray over the area - mebbe an attempt to cover up a problem. either way, im just glad the other side is solid. my mate is back off hols now so we should be able to weld that up and the back of the sills soon - just hope it's only the back of the sills or the skirts are gonna have to come off
Old 30-09-2009, 12:34
chris1986 chris1986 is offline
chris1986 is an unknown quantity at this point
hi guys
i was wondering how to get the rear subframe and the rear arms bushings out
how do you guys do it?
greetings, chris
Old 01-10-2009, 07:06
Burn them out
