Old 01-10-2009, 09:24
If you have the subframe off most just fall out through age. if not then you can just burn them out with heating!. There is a metal collar on the subframe which will also need to be chiselled out CAREFULLY!
Old 01-10-2009, 16:37
alundra alundra is offline
I don't who but he said me those bushings must be recut, the thickness is too large and tends our rear subframe to be lowered.
Are they made by Prothane? Do you still have the ref number?
I appreciate if you'll share some info even minor.
Old 07-10-2009, 14:59
chris1986 chris1986 is offline
chris1986 is an unknown quantity at this point
I got them from Mjp and they are indeed from prothane
the kit number from the rear z31 subframe bushings is #14-101
They seem to be a little larger than the original bushings
greetings.
Chris
