Old 28-11-2009, 11:08
martin.herwitson's Avatar
I've just rebuilt my own and it wasn't too bad a job (I did have to make an input flange spanner and a rounded drift to reinstall the side shims). I would expect you to be able to replace bearings and use the same shims, especially on the input shaft. To measure the backlash you'll need a DTI and if you need to adjust that then you'll be into measuring shims. Good luck....mine isn't in the car yet so if you need pics or info just let me know?
