Old 07-03-2006, 09:29
i put avo springs in my s12 with standard shocks, and it was loads better handling for grip and drifting, and none of them snapped was a bit bouncy when drifting tho i think uprated shocks are fairly expensive?
Old 07-03-2006, 10:03
i used avo springs on the old shocks for about 5 years, no probs, i've now got kyb's all round and new avo's also got the poly bushes for the rear, they are the same as the 280zx and z31 items.
Old 07-03-2006, 10:35
where can you get the rear poly bush kits from? how much are they? what parts do they supply? eg subframe mounting/anti roll bar/trailing arm
Old 07-03-2006, 11:58
Dan Dan is offline
s13eater, which kyb's have you got on the front? I looked at kyb's parts catalog and they only have a part number for rear gas-a-justs. Are you on GR-2's?
Old 07-03-2006, 17:52
they are the same as the 280zx kyb's ones on the front, the superflex bushes where 100 quid for the rear, but that din't include the big subframe bushes, i got, 2 D 24mm anti roll bar bushes, 8 small bushes for the ends of the anti roll bar, and all the bushes for the trailing arms, which is 8 because each 1 is in 2 halfs,i had ally inserts made for the main subframe bushes and used 240z poly bushes inside.
Old 09-03-2006, 09:31
Dan Dan is offline
Anyone know if Chassis Dynamics lowering springs are any good? Anyone here use them?
Old 09-03-2006, 10:39
i think avo + chassis dynamics are the same
