Old 19-01-2010, 12:49
sjef200sxTurbo's Avatar
sjef200sxTurbo sjef200sxTurbo is offline
sjef200sxTurbo is on a distinguished road
I really need to find this module cause i have to check the whole wiring loom.
My car wil only run on false values by cheating the water temp sensor by connecting the ignition signal thru a resistor between the loom and the water temp sensor.
I've been checking all the wiring shemes and it says the ignition signal and al those sensors are connected thru the pressure regulator control module and solenoid.
I just cant find it.
Is it possible my 84 LHD model doesnt have one?
I'm really stuck here.
87 silvia (ca18det)
94 Alfa Romeo 155 2.0 8v ts (daily driver)(planning Lancia Delta swap)
84 silvia (ca18et oldtimer)
Turbolag is nothing but foreplay
