Old 24-01-2010, 23:01
Guess this is still available, what cc are the injectors mate? i currently have 440cc not sure on the maximum hp they will handle with a 255 pump, just checking if the injectors are needed also. is the price delivered?
Old 24-01-2010, 23:17
injectors are 444cc. So long as your pumps up to it and you have an adjustable fuel pressure reg, they should see 300-320hp.
cheers
Craig
Old 24-01-2010, 23:18
what engine management are you going to run?
Old 24-01-2010, 23:57
currently have emanage,but im in the midst of doing a deal with FC Tuning for a prototype NIStune solution,all being well it will be a plug and play fully mappable but based on the stock s12 ecu.will keep you posted on that if you like.
Old 25-01-2010, 09:03
Ah, thats fine, just worried with all the hardware mods you were gonna try and use the std clockwork s12 ecu lol.
a plug'n'play would open up the possibilities for lots of guys on here and the scimitar boys too.
I run an Emerald ecu at the mo
Old 25-01-2010, 20:10
Well as soon as i get mine sorted out and mapped, i will chat with Steve and maybe get him to start a thread on here mods permitting. yhpm regarding inlet.
think i might need bigger injectors eventually if there really only gonna hit 320bhp, would rather not run them at maximum all the time!
Old 25-01-2010, 22:58
mate of mine has two spare ET cranks, will pm his details
Injectors should run to 350ish, using rule of thumb, inj size x 4 divided by 5 = approx bhp, but 320s safe as houses. Run a higher baseline pressure (needs good pump like bosch 044 and decent regulator) and you can go higher safely (ive seen it done anyway).
