Old 11-02-2010, 00:15
slammed 66's Avatar
slammed 66 slammed 66 is offline
slammed 66 is an unknown quantity at this point
Default odd headlamp issue
Hey fellas,
Ive just bought my second silvia this month and this one is to be my every day smoker.
First issue ive found with it relates to the high beam. If i flick it on the lights dim to sidelights only. Dipped beam works fine and so do sides but not mains.
Any ideas what the likely culprit could be?
Many thanks
Ross
p.s. pics of the car to follow
Old 04-03-2010, 00:08
slammed 66's Avatar
Question
Anyone?
Old 04-03-2010, 06:56
marcusp88 marcusp88 is offline
marcusp88 is an unknown quantity at this point
I take it youve checked your bulbs and fuses?
Old 04-03-2010, 14:36
email silviagod but I think its the old problem with the headlight stalk. Basically I think you need a replacement
Old 04-03-2010, 16:36
i had this, it was the stalk, i took it apart and cleaned between the contacts. worked fine ever since
Old 04-03-2010, 17:32
irish s12's Avatar
I had the same and it was a relay down by the airbox,the one for the high beams is on the back of the relay plate,I'd try this first as it's easier than the stalk.
Old 05-03-2010, 16:08
Ronin's Avatar
Ronin Ronin is offline
Silvia Driver
I've had this problem did the same as Umpkin just be careful not to bend the contacts out of shape.
