Old 23-02-2010, 00:10
Raas_s12 Raas_s12 is offline
Raas_s12 is an unknown quantity at this point
hi s13eater
im may siund a little blonde here mate but what does bore wash mean? and do you think i sould get rid of the fifth injector?
Old 23-02-2010, 08:07
Originally Posted by Raas_s12 View Post
hi s13eater
the 5th injectors can supply to much fuel, this will wash the protective lair of oil off of the bore, leaving metal to metal, you need to get it running and then set up on a rolling road and check the afr ratio.
Old 23-02-2010, 19:30
its probs either spark, fuel or compression.
As you have spark then its one of the other two.
It could be a faulty fuel pump,
faulty imobiliser to pump if ones been put in,
faulty fuel pressure regulator
severe boost leak from an intake pipe
Old 24-02-2010, 02:46
thanks a lot for the info guys....i jus wanna say that i have fuel and spark so now its going down to compression........if there is loss of compression what can i do next?
Old 24-02-2010, 14:39
Replace the head gasket or pistons/rings or valves/valve seats depending on what the cause is
Do a test yourself with a compression test kit(get from halfords if need be)
Post up your results.
