thanks a lot for the info guys....i jus wanna say that i have fuel and spark so now its going down to compression........if there is loss of compression what can i do next?
Replace the head gasket or pistons/rings or valves/valve seats depending on what the cause is
Do a test yourself with a compression test kit(get from halfords if need be) Post up your results.
![]() Quote:
