Old 15-03-2010, 13:01
duncan on hear as fitted one.
Old 18-03-2010, 21:42
I'm going to be fitting one, but not done it yet.
Ones I've had in the past have been super effective.
Weld the diff.
Old 18-03-2010, 21:48
am i right you have to keep the mechanical one operational too for MOT?? im sure i read somewhere it will fail if not.
Old 19-03-2010, 07:58
yea you need the standard handbrake to pass the mot as i was going to run a bigger set of callipers on the back that didnt have the s12 type handbrake mechanism and run a hydraulic one but no mod i found would make it pass a test........
Old 19-03-2010, 18:27
MOT station will only look at handbrake links moving, so leave the cables on so it all moves and the hydraulic handbrake makes it look like it works spot on.
Never had any MOT preoblems.
Old 20-03-2010, 13:24
If you want to drift you need o get soe algnment kit. Factory positions are all wrong.
Old 23-03-2010, 12:14
amateursilviadrifter amateursilviadrifter is offline
amateursilviadrifter is an unknown quantity at this point
Default alignment kit
sorry for bein a thicko but what is oem alignment kit and where would one get it?? yeah i want to drift - will go sideways ok - welded diff - but actually getting into a slide with handbrake is tough - poor reponse from handbrake even though feels v tight and holds well - and pads seem ok.. but look into alignment - any advice welcome
