Old 28-03-2010, 12:29
PureButeS12's Avatar
the tansparant hose is my vacume, is this to the correct place?
Old 28-03-2010, 13:49
yeah thats fine. Unplug it and just check its sucking at idle. there could be a block
Old 28-03-2010, 15:44
i've just had all of the boost pipes off & found that the hose on the actuator was split, i've replaced it & reinstalled all the boost pipes but the boost gauge & dump valve are still not working???
does any1 know if the problem is because this dump valve is off an s14, is the spring too hard for 7psi to move?
Old 28-03-2010, 18:58
**update**
i've changed the spring in the dump valve for a lower psi one (donation from a mate) but still no PSSSSSSSHHHHH!
after further examination, the vacume is in the correct place & sucking good, boost pipe are tight & secure, actuator hose replaced & secure, but boost gauge is not budging?
i've noticed the arm on the actuator is not moving when revving?
Old 28-03-2010, 19:05
take the r clip out , the actuator arm off and see if you can open the wastegate, it could be seized matey.
Old 30-03-2010, 21:33
done what you said & the wasgate seems to move ok, only about 10mm tho. when revving the engine with the actuator arm disconnected from the wastegate is doesnt move, does this mean the actuator is broken?
Old 30-03-2010, 23:46
take the pipe from the air filter to the turbo off and check the turbo blades are spinning freely. Ive seen a few silvias with siezed turbo blades in the past.
If its not that you possibly have a boost leak somewhere that is allowing the boost to release from it rather than via the dump valve.
