Old 29-03-2010, 19:35
the V grooved are normally a bit more expensive in UK. Ive used them in road car for many 1000s of miles, never hada problem, possibly a bit better life than std type
Old 29-03-2010, 20:48
Thanks for fast reply! V shaped shipped cost less less than bcpr7es here.
Old 30-03-2010, 07:49
you have a twin spark motor ?
Old 30-03-2010, 08:19
me? not currently, but have had two previously.
i used i heat range different on the exh side plugs as per nissans advice (6s & 7s) as opposed to 5s & 6s iirc)
secondary plugs are only there to burn off any unburnt fuels left from combustion process, was a cheap method of cleaning up exh emissions, before closed loop ECUs were the norm.
disconnecting the 2nd coil has no effect on the dyno graphs
