custom front coilovers, -40mm rear springs, de-spoilered, Bailey dump valve, induction kit, mocal sandwich plate with oil cooler, OMP deep dish steering wheel, unknown jap 14x8" slotmags from 1976 |
You can still get kyb gas shocks for s12's,but as fer as I know you will have to get the springs made by a spring company.If you do a search for lowering springs then you will get the info you need.
I've got 40mm lowering springs but I bought mine from canuc in canada and I don't think they do them anymore.You won't have any problems with them popping out. |
i've already found the KYB fronts on ebay but not rears, i'm goin to call KYB themselves 2mora
Somewhere on here there is info on using some ford escort shocks on the back for really low cars.I think they are shorter and won't allow the spring to pop out.Whatever way,with your car that low it will handle like a dog.
This is how my car sits with 40mm springs.Maybe not the way you want it to look,but in the handling stakes for a road car it is perfect.
Think im getting some S12 designed leda coilovers
Leda coilovers? Do tell.
Gaz do a Leda rebuild service, should they need it.
does any1 have a link for s12 lowering springs cos i can't find them
So IF there should be something wrong with them I can get them fixed up! That's good news! Who's Gaz? Cheers mate
