Old 13-05-2010, 20:45
I want to use the S13 mounts but I cant get the s12 ones unbolted. I cant get a spanner in the gap to unbolt them. I aint dropping the subframe.
Old 13-05-2010, 20:46
Ah shit, yeah you need a bit of a bent spanner.
Old 13-05-2010, 20:52
I will try and bend a spanner tomorrow with a *ucken big hammer
Do you think the s12 mounts will be ok ? after all they are only 2 bolt v 3 bolt
Old 13-05-2010, 20:56
Well it depends, if you're a lunatic trying, drifting, dumping the clutch etc then a weakness in those bolts will show up.
In my old S12 I had the bolts shear on the inlet side. The engine dropped a few inches. It didn't drop any further because the oil filter stuff itself in to the side of the amount. Made a hole in the oil filter though.
Old 13-05-2010, 20:59
H'mmm I think I will try and bend a spanner tomorrow. If I cant undo them, they will have to stay stock
Old 13-05-2010, 23:24
irish s12's Avatar
I've been using the s12 mount's for a couple of years without any problems.
Old 14-05-2010, 07:40
Thats what I needed to hear! Thanks matey!
Did you find the same problem when installing the
DET ??
Old 15-05-2010, 19:24
your failure was due to difference in bolt length and thread depth in the block I seem to remember??. I think it would have been fine if the difference had been identified before.
Old 15-05-2010, 19:45
Can't remember I'd have to look back at threads. I know it happened to Adam too. I found the pic of the what (both bolts) had remained in the block. They don't look too long to have bottomed out though.
EDIT - Had a thought - I think one of the bolt holes in the DET block isn't used for the S13 brackets, but is for the S12 brackets. Maybe the thread isn't cut as deep as on the S12 blocks?
Old 15-05-2010, 20:12
Oh well its in now and unless anything happens (fingers crossed) its staying put
