Old 20-05-2010, 11:09
The temp switch is activated at 90 degree's ie when the temp is roughly in the middle of the gauge. Even if the engine was hot it should start. To rule out the fans which I'm certain is not the fault, I've got a few of the standard water pump bolted fans. If you sort me out the postage, I could send you one.
