Aye that'd be my preffered choice but getting all the parts from a manual S12 is hard, plus would need a complete list of parts I'd need. Wouldnt even know how to check if parts are in good condition. Any breaker yards over here i've found have no S12's. Plenty of S13's breaking though.
May take that starter off you S13eater to see if it helps at all. |
ok matey, just let me know if you want it and i'll get a price for postage.
for the transplant you will need :
S12 gearbox flywheel/clutch insert a new spigot bush into the flywheel end of the crank clutch pedal, clutch master cylinder and slave cylinder plus make up the lines. you maybe able to use the auto prop shaft (have to check it fits a manual box) have to adapt the auto box mount to fit the manual box then you would need the interior piece around the gearstick then unplug the auto brain which is inside the NSR 1/4 panel ![]()
you could get most of your conversion parts from hear
http://cgi.ebay.co.uk/NISSAN-SYLVIA-...item35a9be5db4
