the Et pistons do have the four valve reliefs in the top but I remember Eddy from zxoc years ago comparing them to a DET piston. The tops were the same but the grooves etc were different
hey mate yeh its a bit of a weird one just trying to work things out gonna have the pistons dished,so i was just trying to work out if theyd be good enough so cheers for that info.
aaron |
aaron |
there not really good enough for much to be honest, If your going to have machining done and fit new rings obviously then there really is no reason not to upgrade the pistons to at least a det 16v rod/piston setup. There so cheap to buy
what lengths are the det there obviously shorter, but will they fit the 20?. i wanna keep it a 20 no matter what as i am all for being origanal and the laws here in aus are sh#3t! though i work for an engine builder that builds sprint cars and all sorts of things so putting this together will be fun.
8V pistons have 4 reliefs in the pistons for a very simple reason. It's so they can have one single casting of piston. Otherwise they would have to cast 2 pistons to match cylinders 1&3 and 2&4.
You'll notice the cutouts on an ET and DET are completely different
sorry, i thought you had a ca18et and were wondering if you had ca20's
ca20 engined s12s werent available in the Uk mate.
oh ok no worries yeh i might see how i go mabe get some after market slappers and mabey new rods i gotta finish all the head work yet anyway, our s12's are mostly only 20s some import 18's but very few here in aus is mostly the reason im signed up with uk silvia because the 20 and 18 bits are the same so ive sourced a couple of bits through here and much rather the different insight, you wouldnt happen to no anything about a body for it or can i customize an s series kit? and i really need a new rear lip as some bastad broke it!
