Go Back   S12OC UK Forum > Main Categories > Daily Chat
Old 20-06-2010, 10:58
there not really good enough for much to be honest, If your going to have machining done and fit new rings obviously then there really is no reason not to upgrade the pistons to at least a det 16v rod/piston setup. There so cheap to buy
Old 20-06-2010, 23:43
800horsepower 800horsepower is offline
800horsepower is an unknown quantity at this point
what lengths are the det there obviously shorter, but will they fit the 20?. i wanna keep it a 20 no matter what as i am all for being origanal and the laws here in aus are sh#3t! though i work for an engine builder that builds sprint cars and all sorts of things so putting this together will be fun.
Old 21-06-2010, 00:18
8V pistons have 4 reliefs in the pistons for a very simple reason. It's so they can have one single casting of piston. Otherwise they would have to cast 2 pistons to match cylinders 1&3 and 2&4.
You'll notice the cutouts on an ET and DET are completely different
Old 21-06-2010, 00:41
sorry, i thought you had a ca18et and were wondering if you had ca20's
ca20 engined s12s werent available in the Uk mate.
Old 21-06-2010, 01:53
oh ok no worries yeh i might see how i go mabe get some after market slappers and mabey new rods i gotta finish all the head work yet anyway, our s12's are mostly only 20s some import 18's but very few here in aus is mostly the reason im signed up with uk silvia because the 20 and 18 bits are the same so ive sourced a couple of bits through here and much rather the different insight, you wouldnt happen to no anything about a body for it or can i customize an s series kit? and i really need a new rear lip as some bastad broke it!
Old 21-06-2010, 19:57
Have you tried the Aus S12 site ? We only ever got the CA20E in FWD form and even then only on one specific model so very rare.
Old 21-06-2010, 23:11
oldskoolbeasts oldskoolbeasts is offline
Banned
oldskoolbeasts is an unknown quantity at this point
As far as i know, et and 20 pistons and rods are the same, the CA20 gets its extra capacity due to a longer stroke on the crank! hence, if someone ever wanted to build a serious ET or DET with a 2.0 capacity, use a CA20et crank!!!
Rare as rocking horse s**t to find and wicked expensive but the only job for some serious ponies!!! Norris designs supply a stroker kit with this crank off the shelf, but u need a big fat wallet!!!
CA18DET rods and pistons would still make your CA20 bottom end stronger if your trying to get as much power as possible from it and a cheap upgrade! i can sort you out with a set if your stuck mate!
BTW, Any chance of findn me a ca20 inlet manifold bud?!...
Old 22-06-2010, 12:34
yeh we have millions in fwd, but im mostly after bits from the euro's because we only have crap over here, im using a fwd ca20 inlet manifold cut and re welded aswell as all of its ignition as its newer and has better sensor set up.
