You need to use BB code on this forum mate, HTML is disabled. (FYI)
Anyway, this is yours: ![]() ![]() ...and this is std: ![]() I would imagine urs had an intercooler at some point in it's life, it was taken off prior to selling and the boost pipe bodged back together. So in short, just buy some silicone hose or get a proper boost pipe and elbow pipe of a breaker here ![]()
Ahhh I see so the whole things a metal pipe that'll be why its
So expensive would a silly c#nt hose be ok pressure wise? Or would the original part be better? M.T |
The original boost pipe to turbo hose is an orange silicone jobbie and the boost pipe to inlet manifold is rubber so you'll have no issues.
That being said, it is dependant on your metal pipe having a lip at each end for the juby clips to grip behind - without that, if you're on full boost and slam the throttle plate closed, the pipe will blow off and scare any old grannys in the vicinity :P
Thanks man. This has been very helpful. After I fix this
Its on to getting new rad as mine is starting to rot. Thanks again. M.T |
