Old 13-09-2010, 17:57
s12pickup s12pickup is offline
s12pickup is an unknown quantity at this point
Default re dump valve
dont mind sound of backspin but apparently can cause damage to turbo ,or it to stall.dump valve reduces risk of this.(this is what ive been informed).cheers
Old 13-09-2010, 19:26
What boost pressure are you running?
Its not nessesery on a T2 and mine never stalls, id save you money for something else
Old 13-09-2010, 19:59
i think its a t25.
Old 14-09-2010, 00:28
it is a t25.only running 7-8 psi at minute.changing plugs on thursday and then going to turn boost up a bit now intercooler ok.any suggestions what psi should be ok.
Old 14-09-2010, 09:31
i think between 10 and 12psi, you could do with it set on the rolling road, then it could be notched up and keep an eye on the afr at the same time
Old 14-09-2010, 13:47
Default psi
going to merlins rolling rd nr ollerton.got 1000bhp dyno set up .quite cheap too.soon as ive done faffing its goin there.what is afr (air fuel ratio ????)if it is this thats why i want to know which cars are same thread as lamda blank in manifold.ill get there eventually its all a learning curve for me.cheers
Old 14-09-2010, 13:52
ahh got you, you want to use the lambda to check your air fuel ratio, thoght you was meaning you wanted to use a lambda in the ecu.
